Author Topic: How would you position your bed in your next Conversion?  (Read 12334 times)
  • Publisher - BCM
  • Administrator
    • BCM
« on: June 02, 2024, 07:50:06 AM »
If you were to convert another bus, how would you position the bed?
Would you position it with the head of the bed at the rear of the bus, or would you position it along the side of the bus, and why?
And what size bed(s) and how many beds would you have?
If you had slides, would may make a difference.
Offline lvmci
  • lvmci
Re: How would you position your bed?
« Reply #1 on: June 02, 2024, 09:29:09 AM »
Lots of passenger busses come with lights over toilet or at toilet door or both. When it comes time to put cabinets or headboard
above or around bed, you have builtin wiring and bulb for reading over the bed. So head towards back...
MCI 102C3 8V92, Allison HT740
Offline Jim Blackwood
« Reply #2 on: June 03, 2024, 07:51:39 AM »
I put the head to the back just for symmetry. His-n-her wardrobes as you come into the BR then same way around each side. Center isle. With a side isle maybe put it to the side.
Offline epretot
« Reply #3 on: June 03, 2024, 01:06:54 PM »
I wouldn't lose sleep over it.
2000 MCI 102 DL3
Loveland, OH
  • Publisher - BCM
  • Administrator
    • BCM
« Reply #4 on: June 03, 2024, 02:03:45 PM »
Offline windtrader
« Reply #5 on: June 03, 2024, 09:46:33 PM »
#1 on my project list is to reorient the bed. Bus is MC8, 96" wide, bed at back. It faces sideways and there is too little room to get around the end. Maybe a shorter bed would work, we are not tall.
There is a massive storage closet along the back wall and if reposted front-back, the bed can use some of that space, providing more free space along the end and the sides.
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
Offline Dave5Cs
  • BCM Subscriber
Re: How would you position your bed in your next Conversion?
« Reply #6 on: June 04, 2024, 09:52:31 AM »
head at back 14inches around all sides, the other way there is no room at back or end. It is already tough for two old people to make the bed now. :^ :^
Offline Van
« Reply #7 on: June 04, 2024, 10:19:39 AM »
With out slide outs we would never even consider anything other than a North South configuration. To each their own however. ;)
  • Publisher - BCM
  • Administrator
    • BCM
« Reply #8 on: June 04, 2024, 10:32:40 AM »
Do you always park your bus facing North?  :o
Offline lvmci
  • lvmci
« Reply #9 on: June 05, 2024, 07:02:30 AM »
Gary, don't you use feng shui, when you park your bus?...
Offline oltrunt
  • A fine BCM outting
« Reply #10 on: June 05, 2024, 08:22:43 AM »
which way does the fireplace need to face--I can never remember.  Jack
  • Publisher - BCM
  • Administrator
    • BCM
« Reply #11 on: June 05, 2024, 09:21:55 AM »
which way does the fireplace need to face--I can never remember.  Jack  ;D
The Fireplace should always towards the bed, never away Jack.
Offline plyonsMC9
  • Global Moderator
  • Big Wheels Turnin'
    • PhilLyons.com
« Reply #12 on: June 09, 2024, 09:25:02 PM »
I like the bed, in the back, headboard straight against the rear wall - in the middle left-to-right, facing up the main isle. So if I want, I can see from the back to the front windshield.  I like that more spacious view.  You can walk around the bed on either side.  If I want privacy from the rest of the bus I close the doors.
The Vantare MCI DL345 we purchased (IIRC 1994 model) had the bed almost diagonal in the back.  With a TV that popped out (motoroized) at the foot of the bed, at the same diagonal type angle.  I never could get used to that.  It's been replaced.
Take care all, Phil
