BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Another Starting Issue
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Another Starting Issue (Read 9058 times)
epretot
Sr. Member
on:
July 24, 2024, 03:19:47 PM »
I replaced 9 dashboard bulbs today. I think with the wrong voltage. The bulb panel shows 12 Volts. The manual shows 24 Volts.
I started the bus and after the lights that initially come on went off, I pressed the bulb test switch to see the new lights.
The engine died. It blew the 5 amp ECM fuse.
After replacing it. I tried to start the bus again with no luck. At some point the fuse blew again.
I removed all of the bulbs and replaced the fuse again. I'm no long getting a blown fuse but the bus isn't starting.
Thoughts?
Logged
2000 MCI 102 DL3
Loveland, OH
windtrader
Hero Member
Re: Another Starting Issue
Reply #1 on:
July 24, 2024, 09:54:14 PM »
If you opened the dashboard to change the bulbs and that panel is where other switches, buttons, and gauges, are mounted with wires running here and there, then you could have disconnected or loosened one that impacts the start circuit.
Logged
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
epretot
Sr. Member
Reply #2 on:
July 25, 2024, 04:53:34 AM »
It was suggested to me to separated the two start batteries and charged them separately.
One is taking a lot of amps.
Likely replacing them both.
I believe I had two unrelated issues occurring simultaneously.
The short blew the ecm fuse.
The batteries were too weak to restart once the short was remedied.
Logged
2000 MCI 102 DL3
Loveland, OH
Print
Pages: [
1
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
