Author Topic: Differential Oil Analysis - Recommended Lab?  (Read 10319 times)
Offline plyonsMC9
  • Global Moderator
  • Big Wheels Turnin'
    • PhilLyons.com
« on: October 15, 2024, 10:30:38 PM »
Good evening Bus Folks!
Is there a recommended lab for differential oil?    I'm hoping the results would show problems, etc., and what oil is actually in the differential - especially synthetic vs standard.
I inspected what I could, and it doesn't smell strong as I might expect w/ standard, and it's mostly clear.  Sooo - if the oil is synthetic and in good shape, I would not want to go through the expense of changing it out, maybe just top it off a quarter inch or so, if that, below the fill plug.  If it's standard I'm thinking to have it replaced w/ synthetic or just replaced w/ standard, and then I'd know exactly what was in there.  From that point I could maintain it properly.
This is for a '93 DL3-45.
Thank you for thoughts, suggestions!,
Phil
Offline RJ
  • VantarĂ© Conversion "Miss Vivian"
Re: Differential Oil Analysis - Recommended Lab?
« Reply #1 on: October 16, 2024, 02:26:54 AM »
Phil -
I use Blackstone Labs for all my oil analysis. They'll send you sample bottles with free shipping, last sample analysis cost $40.
blackstone-labs.com
« Reply #2 on: October 16, 2024, 06:23:38 AM »
Phil
Your local CAT dealer has the best ,you can get the sample bottle and suction gun there ,check Empire CAT in your area for supplies,never take a sample from a oil pan or gear box  plug ,The John Deere dealer in Prescott should do oil sampling too
Offline plyonsMC9
  • Global Moderator
    • PhilLyons.com
« Reply #3 on: October 16, 2024, 10:54:48 PM »
Much appreciated gentlemen!  I shall follow up this post w/ the results.
Kind Regards, Phil
