Active Controls LLC specializes in electronic devices to help RVers access power as efficiently and effortlessly as possible.
They recently introduced two new products, ACS20PT and ACS2PT-S (20 amps), designed to start high amperage loads such as an A/C unit, Air Fryer, Instant Pot, and many other high-energy draw appliances.
This allows other minor loads to run on the unit, but only one large motor can be started at a time until the unit is ready for the next load with the ACS30P and ACS50P products.
You can use it to run the larger plug and play units you do not have to do 1 large load at a time as it can handle multiple large loads. , but only one appliance at a time to reduce the inrush of current.
With programmable startup power, these devices monitor your system’s health, including current, voltage, and frequency.
The mobile app is Bluetooth-enabled and compatible with iOS and Android devices.
Visit
https://active-controls-llc.myshopify.com/.../activestart... to learn more about their products and when you check out, be sure to enter the discount code BCM5 to receive a 5% discount on any purchase.
Click here to read an article about what one bus conversion customer says about this product.
https://www.busconversionmagazine.com/.../howtogetbyon30.../
