BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Pulling 6000Ib Trailor
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: Pulling 6000Ib Trailor (Read 6689 times)
johns4104s
Hero Member
on:
January 11, 2009, 01:57:33 PM »
I am looking at pulling a trailer and car. The total weight of both is 6000Lbs. I have a 8v92T and Allison 750, Does anyone have the experience with about the same set up? What would be the difference in MPG without this load. Any input would be appreciated.
PS The trailer is a open car hauler
Logged
Jerry32
Hero Member
Re: Pulling 6000Ib Trailor
Reply #1 on:
January 11, 2009, 02:21:20 PM »
My bus comes in at about 32000 lbs so pulling a 4000 lb toad makes for normal load. I get about 7 MPG that way. Jerry
Logged
1988 MCI 102A3 8V92TA 740
Hero Member
Reply #2 on:
January 11, 2009, 04:03:52 PM »
The biggest issue you're going to have is tongue weight. An 8V92 with your bus probably will hardly notice the weight of the trailer.
Logged
rv_safetyman
Hero Member
Jim Shepherd
Reply #3 on:
January 13, 2009, 08:35:32 AM »
Hi John.
The subject of pulling a trailer comes up here quite often. There are a bunch of threads that have lots of discussions.
You will not have any problem with power and at the worst, you might see a .5-1.0 MPG reduction (maybe less - lots depends on your right foot).
The real issue is the hitch structure. Before I get into that, I assume you have weighed your combination. My guess is that is a low figure if you have a standard size car and a good trailer.
The issue with the structure is the ability to handle vertical loads. If your weight is correct, you will have at least 600 pounds on the hitch. That is quite a bit, since the hitch structure is hung off the engine cradle system.
At one time, I was going to write an article for George Myers' publication, and I accumulated quite a bit of information. I have that posted at:
http://www.rvsafetysystems.com/Trailer%20Towing.htm
Logged
Jim Shepherd
Evergreen, CO
Bus Project details:
http://beltguy.com/Bus_Project/busproject.htm
Blog:
http://rvsafetyman.blogspot.com/
Guest
Reply #4 on:
January 13, 2009, 08:48:57 AM »
John, I tow a trailer with a tractor behind my Eagle weighing around 10,000# that has a 8v92 and a 740 never had any trouble and I do this about 2 times a year from AZ to TX and back and I have not noticed much fuel mileage or power difference
Logged
WEC4104
Hero Member
Reply #5 on:
January 13, 2009, 10:27:25 AM »
John:
Can we get a clarification on the coach make/model you are talking about? From your board user name, it sounds like you have a GMC 4104, but your reference to the 8V92T has me doubting that. Maybe you have multiple coaches, or bought something new without changing your board name. The photo next to your name is too tiny for me to make out exactly what model it is.
If you truely have a 8V92T in a 4104, then obviously you have enough horsepower/torque to tow whatever you want. But as already mentioned, tongue weight is a concern. If there really is a 8V92T in the back of a 4104, there was some serious modifications done to get it to fit, and who knows what the cradle looks like today. We would only be guessing at what additional tongue weight could be added.
Logged
johns4104s
Hero Member
Reply #6 on:
January 13, 2009, 11:28:18 AM »
Although I trarted 26 years ago with a 4104, I have recently purchased a MCI 9 the the 8v92T and 750 combination.
Logged
Eagle
Sr. Member
1985 Eagle
Reply #7 on:
January 13, 2009, 12:38:48 PM »
I have seen these posts numerous times on these forums about towing a trailer or toad. Personally I think we should be asking about a braking system in stopping these things rather than whether we have enough power to pull them.
Logged
Guest
Reply #8 on:
January 13, 2009, 01:09:36 PM »
Eagle, I have electric brakes on my trailer (both axles) and with the new brake controllers no excuse not to have brakes on the trailers it just takes 1 wire to the back now good luck
Logged
Eagle
Sr. Member
1985 Eagle
Reply #9 on:
January 13, 2009, 01:56:43 PM »
That's great luvrbus but my thoughts are very few folks seem to be worried about stopping these things.
Logged
johns4104s
Hero Member
Reply #10 on:
January 13, 2009, 02:14:30 PM »
Eagle.
Great point, I do have breaks on both axles.
Logged
skipn
Guest
Reply #11 on:
January 13, 2009, 02:24:19 PM »
There are several sites but here is one
http://www.boatwheels.biz/brakelaws.pdf
Doesn't really matter what your bus can handle ... I do know Idaho checks even out of state rigs.
This may not include toads that is usually another set of laws.
FWIW
bye bye
Skip
Logged
white-eagle
Hero Member
Reply #12 on:
January 14, 2009, 05:45:09 AM »
we pull a chevy express van loaded with tools, nuts, bolts, cable, so probably 5-7000. i have not noticed any problems with engine, or towing. we ran 70-75mph from fl to al yesterday. we do have a 10000 lb hitch and tow bar. and yes, we do now have a brake system. (thanks to assistance from Marty Gross and Ed Roehle).
mileage on the way down from ohio to florida, 7.2mpg. 8v92 with 740.
Logged
Tom
Hero Member
Reply #13 on:
January 14, 2009, 07:21:49 AM »
I guess I always assume anyone buying a trailer with a GVW high enough to handle a car will be buying a trailer with brakes. Unless you build your own trailer it would quite unusual for a manufactured trailer not to have brakes.
Logged
Guest
Reply #14 on:
January 14, 2009, 07:39:41 AM »
That's very true Belfert about manufactures but some stay within the law by just installing brakes on 1 axle on a tandem trailer good luck
Logged
Print
Pages: [
1
2
All
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
