Author Topic: Toad or Trailer – That is the Question  (Read 29315 times)
  • Publisher - BCM
  • Administrator
    • BCM
Re: Toad or Trailer – That is the Question
« Reply #45 on: May 16, 2016, 12:49:33 PM »
Another advantage of an enclosed trailer is that if you travel thru any snow, sand, sleet, salt, hail, or other storms or just pouring rain it keeps your car clean rather than covering it with the mess kicked up from the rear tires of the bus.  I have seen some pretty dirty cars and broken windshields as a result of towing.  Does anyone using an enclosed trailer feel this advantage is worth the extra expense and inconvenience?
Offline chessie4905
« Reply #46 on: May 16, 2016, 03:51:28 PM »
In that kind of weather, I stay home. Yes, if you drive in those conditions, then a trailer makes sense.
Offline RJ
  • Vantaré Conversion "Miss Vivian"
« Reply #47 on: May 16, 2016, 09:02:54 PM »
One distinct advantage of having a trailer vs. a Toad is that you put less mileage on your car thereby not causing extra depreciation.  Has anyone ever considered this issue or don't we have any bean counters driving buses.
My toad is so old, depreciation isn't an issue anymore.  I'm sure it's the same for many others, too.
Offline Oonrahnjay
« Reply #48 on: May 17, 2016, 08:15:20 AM »
    My toad is so old, I've forgotten what depreciation is!  No, wait a minute, that's *me* that's so old ...
Offline DoubleEagle
  • BCM Subscriber
« Reply #49 on: May 17, 2016, 08:27:36 AM »
Depreciation would only apply to commercial business use, which would require CDL's and DOT inspections complicating our lives. We are better off with our old buses and toads.
Walter
Dayton, Ohio
Offline kyle4501
  • NEWELL in South Carolina
« Reply #50 on: May 17, 2016, 05:47:15 PM »
Not the kind of depreciation I was thinking about. I was thinking he meant that higher miles means lower resale value . . . .
  • Publisher - BCM
  • Administrator
    • BCM
« Reply #51 on: May 17, 2016, 06:10:04 PM »
Yes, that is correct.  More miles means more wear and tear and every mile devalues your vehicle whether it is commercial or privately owned.  The last IRS value I heard was 58 cents per mile, but it is probably higher now.
Offline DoubleEagle
  • BCM Subscriber
« Reply #52 on: May 17, 2016, 07:18:08 PM »
Our vehicles are so old that the traditional depreciation rates do not apply. The value of most running buses have bottomed out to a market value based on condition and visual appeal. The value of a well-maintained coach could remain essentially the same for years, changed only by inflation, the general condition of the economy, and the price of diesel fuel. Our buses defy the normal schedules because they last so long. It is sort like buildings that an accountant might pronounce as having a useful life of 40 years and bases the depreciation schedule on that assumption when there are many buildings that last well over 100 years. If no maintenance occurs on a bus it will lose value alright, but what about the busnuts that repower with new engines and transmissions? Their value will appreciate.
Walter
Dayton, Ohio
  • Publisher - BCM
  • Administrator
    • BCM
« Reply #53 on: May 17, 2016, 07:28:55 PM »
This thread is about Toads, not buses.  Toads depreciate unless their depreciation value has run out.
Offline DoubleEagle
  • BCM Subscriber
« Reply #54 on: May 17, 2016, 07:34:02 PM »
Nope, my 4X4 toad is so old (and rare) that the value is going up.
Walter
Dayton, Ohio
Offline Oonrahnjay
« Reply #55 on: May 18, 2016, 05:36:12 AM »
     Yeah, my TDI wagon (399,825 miles this AM) has gone up 1000% in value in the past year!   I can prove it mathematically -- $0 X 1000% is $0!
Offline Lin
  • 1965 MC-5a
« Reply #56 on: May 18, 2016, 01:54:24 PM »
Depreciation of the toad only makes some sense if you have a pretty new vehicle.  Although, since all of them probably have electronic odometers, towed mileage would not even show.  I paid 2500 for our '99 Cherokee and Kelly lists its private party value, taking into account mileage and condition, as 2500.  It only has 206,000 miles on it, but even if the towed mileage showed on the odometer, which it doesn't, I doubt it would make an real difference.  Certainly, to be fair to the potential buyer, one should disclose that it was used as a toad.  I think that that could even add value to it since it is ready to go in the same capacity.
  • Publisher - BCM
  • Administrator
    • BCM
« Reply #57 on: May 18, 2016, 02:07:01 PM »
What if I towed it backwards half of the time? Would that zero out the depreciation? Or if I towed it backwards all of the time, would it increase in value?  Any Bean Counters out there?
Offline Dave5Cs
  • BCM Subscriber
« Reply #58 on: May 18, 2016, 02:40:51 PM »
1998 Jeep Wrangler TJ so no don't really care. Most wreaking yards and parts places have every part that breaks or you need to keep them going to include many Tubs or bodies, tops, hoods, fenders, engines, tranny's etc for any year. It holds is price and has actually gone up since I bought it last year. New cars are just for looks and make banks money. Life is good!... 8)
Dave
Offline gg04
  • Full throttle 'til you see God
« Reply #59 on: May 18, 2016, 02:58:26 PM »
When we pull our Ranger it's normally on a trailer, but we have used a dolly changed back tires, and pulled the drive shaft when going to venues that have limited space.. Our toad is normally much more important than the bus. rdw
If you personally have not done it  , or saw it done.. do not say it cannot be done...1960 4104 6L71ta ddec Falfurrias Tx
