Author Topic: Toad or Trailer – That is the Question  (Read 29313 times)
  • Publisher - BCM
  • Administrator
    • BCM
« on: May 03, 2016, 05:00:35 PM »
What is the answer?
Offline lostagain
Re: Toad or Trailer – That is the Question
« Reply #1 on: May 03, 2016, 05:18:56 PM »
Gary, we went to Florida and back this winter, (after seeing you at the dam rally in Nov), towing the VW Jetta on a car dolly. It works but it is a PIA. The dolly broke twice and we had to get it welded near Houston, and again in Alabama. Then when you get somewhere, you have to unhook everything and put the trailer somewhere, which actually wasn't a problem. We had to get tires for the trailer in Del Rio TX. None of it is a huge problem, but towing something 4 down would be so much simpler and easier. We have a Suzuki Tracker that I have to finish prepping for next winter's trip.
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
« Reply #2 on: May 03, 2016, 05:48:25 PM »
I tried the trailer route in 2000 they are a real pain dealing with parking,unloading,tie downs,ramps, weight and maintenance I bought us a Jeep and never looked back and I sure didn't miss the trailer and the electric brakes.Towing 4 down a vehicle will follow the same tracks as the vehicle doing the towing also a trailer won't,only problem you run into with a tow bar is backing up
Offline kyle4501
  • NEWELL in South Carolina
« Reply #3 on: May 03, 2016, 06:13:46 PM »
I would think the answer depends on how you plan to use your rig.
If you travel to a single destination & stay there long enough, dealing with parking the trailer may not be much of a problem.
An enclosed trailer would provide storage options also.
I considered a trailer, but for my planned usage, a flat towed 4x4 pickup truck seems to be the best option. The effort required to deal with the trailer soon convinced me that the tow bars were a much better idea.   ;D
Offline DoubleEagle
  • BCM Subscriber
« Reply #4 on: May 03, 2016, 07:04:17 PM »
I have towed a Series Land Rover, which is very handy to tow because I have unlocking hubs on all four wheels, but backing up any distance (without someone in the vehicle steering) is difficult. I also have used a tow dolly, which works out for front wheel drive cars nicely, but again, backing up is not handy. A open or enclosed trailer allows you to back up with precision, and for any distance you can handle. That gives you more options for parking, instead of seeking out pull-through spots all the time.
Walter
Dayton, Ohio
Offline gg04
  • Full throttle 'til you see God
« Reply #5 on: May 03, 2016, 07:22:24 PM »
Have duel trailer hitch for centered tow dolly or trailer, and Jones offset for 4 down. Either of the three takes me about the same time and energy... rdw
If you personally have not done it  , or saw it done.. do not say it cannot be done...1960 4104 6L71ta ddec Falfurrias Tx
Offline muldoonman
« Reply #6 on: May 03, 2016, 07:59:29 PM »
Toad. Unhook the bar and lights and go. Reverse and 4 or 5 minutes you're good to go the other way. Tow a 2014 Ford Super Crew 4x4 now. Had a 2011 Ford Edge 2 wheel drive before this one. Both fast and easy.
« Reply #7 on: May 03, 2016, 08:32:08 PM »
 ;D ;D ;D I am still wondering why Gary needs a tow bar or a trailer all I ever see him riding around is a electric bicycle it could be he bought a 3 wheeler
« Reply #8 on: May 03, 2016, 10:54:47 PM »
I have my Mercedes 300 Turbodiesel modified for 4 down towing. It tows well except you can't back up with it. On my truck I solved that by carrying my car (small car like Toyota Yaris) inside instead. Now I have room to tow a Ranger Tug 23. Good Luck, TomC
Offline Beesme
  • 62 pd 4106 8v71 86 Newell classic wide body 8v92 turbo
  • 1962 pd4106 86 newell
« Reply #9 on: May 04, 2016, 03:35:15 AM »
4 down for sure! My rabbit pickup so easy . Quick connect literally seconds and im unhooked
Bruce E.        62 pd4106 vs730.
Gonic N.H.
Offline chessie4905
« Reply #10 on: May 04, 2016, 03:45:49 AM »
Toad...Suzuki 2 door Vitara 4wd. Also I can tow the coach home if it breaks down, or gets stuck.
Offline sledhead
« Reply #11 on: May 04, 2016, 04:32:02 AM »
I have towed 2 trucks 4 down and now use a light aluminum car float trailer . after 1 or 2 trips with it you get fast at loading and unloading and it tows way better then 4 down + I can back up and I have brakes on the trailer . yes you need a place to put it and I use it for other things as well
dave
dave , karen
Offline gumpy
  • Some Assembly Required
  • Slightly modified 1982 MC9
    • bus.gumpydog.com
« Reply #12 on: May 04, 2016, 05:38:47 AM »
4-down, hands down.
I've towed a vehicle probably 75K miles with my bus; 3 Explorers and a Ranger. With the later Explorers and the Ranger, I had the neutral shift kit
installed to shift the transfer case into neutral for towing.
I wired diodes into the taillights and mounted a 6 prong trailer connector on the front. Generally, I can hook up and be ready to roll in under 5 minutes.
Offline Boomer
« Reply #13 on: May 04, 2016, 08:21:09 AM »
Another advantage of towing 4 down is (heaven forbid) you can push the bus in an emergency.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
Vancouver, WA USA
« Reply #14 on: May 04, 2016, 08:30:01 AM »
LOL a Jeep is handy for that BTDT
