Author Topic: Air system maintenance  (Read 2449 times)
Offline windtrader
« on: November 18, 2020, 08:00:21 AM »
Preventative maintenance on air systems on the bus. Is there anything to do to keep the air lines in good shape? I'm thinking of something you inject that flows through that removes any buildup or particulate matter over the years. I've not seen any mention of such procedures but figured I'd ask.
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
Offline richard5933
Re: Air system maintenance
« Reply #1 on: November 18, 2020, 08:06:40 AM »
I get where you're going with this, but wouldn't doing that make any settled crud airborne again and likely to cause more problems than you'd possibly cure? I'm picturing all kinds of previously settled crud making its way through control valves, causing no end of problems moving forward.
Seems like draining the tanks daily is the main maintenance item. Other than that, periodic inspection for hard/dry air lines or other problems.
Offline lostagain
« Reply #2 on: November 18, 2020, 08:45:20 AM »
No additives. Just service the air dryer regularly. Drain the ping tank often.
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
Online luvrbus
« Reply #3 on: November 18, 2020, 08:57:15 AM »
PM also includes replacing the compressor discharge line or cleaning the latter I cannot make work that line builds up a lot of carbon inside and will give problems and change the intake filter at least 1 a year if equipped with one
Offline windtrader
« Reply #4 on: November 18, 2020, 08:26:27 PM »
Drain tanks and change filter if compressor uses one. thanks and crap, one more thing on the bus todo list. I guess seeing them all checked is a diesel exhaust induced delusion. lol
Don F
Fully converted
Bought 2017
Online luvrbus
« Reply #5 on: November 19, 2020, 05:14:06 AM »
You should change the unloader valves they carbon up too,it is not science anyone can do it.I have people here all the time thinking they need a new compressor all they need is unloader valves for 20 bucks
Offline Dave5Cs
  • BCM Subscriber
« Reply #6 on: November 19, 2020, 04:42:12 PM »
Don they are on top of your compressor and have to go through the floor access.
