Author Topic: 4106 front wheel bearing ring nut tool  (Read 2235 times)
Offline fortyniner
« on: January 16, 2021, 03:45:27 PM »
What does everyone do for the inner front wheel bearing ring nut tool? This is the ring nut with two holes for a pin drive socket.
I need to replace the front bearings and it requires 200lb torque to seat bearings so the right tool would be needed
As an alternative I was considering using the 2 1/2 lock nut to do job that then swap it out for the ring nut.
-Tom P.
Tom Phillips
PD4106-453
PD4106-2864
87 Alfa Milano
93 Range Rover
87 190e-16 Mercedes
92 Jeep Comanche
Offline Utahclaimjumper
Re: 4106 front wheel bearing ring nut tool
« Reply #1 on: January 17, 2021, 05:06:48 AM »
 Measure across the pin holes and buy a pin type  spanner wrench..>>>Dan
Utclmjmpr  (rufcmpn)
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Offline dtcerrato
« Reply #2 on: January 17, 2021, 01:28:21 PM »
We make shifted using a piece of steel angle with two hardened bolts spaced to fit the hole distance.
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Offline fortyniner
« Reply #3 on: January 18, 2021, 07:14:20 AM »
Thanks for suggestions. If I can source one easily Ill fab it then.
Tom Phillips
PD4106-453
PD4106-2864
87 Alfa Milano
93 Range Rover
87 190e-16 Mercedes
92 Jeep Comanche
« Reply #4 on: January 18, 2021, 07:27:12 AM »
You can buy the spanner for under 30 bucks on Amazon it the pins are to short you remove the pins and use longer bolts in place of the pins
Offline Jim Blackwood
« Reply #5 on: January 18, 2021, 11:04:23 AM »
They also sell adjustable pin spanners that work very well. Just have to buy one with the right size pins and then it will work on any pin spacing.
« Reply #6 on: January 18, 2021, 11:15:00 AM »
I have a OTC problem you run into is the pins are not long enough to reach those on some buses they are recessed to deep my pins are removeable so I just bolts for extra length
