Author Topic: Are the fans loud on the Magnum Energy inverters?  (Read 5169 times)
Offline belfert
« on: August 29, 2021, 06:19:27 PM »
I am just having a horrible day.  Broke the inverter in the bus, my car has a coolant leak, and I need a new starter for the Kubota diesel in my lawn mower.  $3,000 to fix/replace everything.
Do the Magnum Energy 4024 inverters have loud fans?  I broke my inverter and I want to put the new one in a location that would bother people sleeping if the fans are loud.  Any reason to get the hybrid inverter if never plug in except at home?  I run the generator when necessary when away from home.  Never on a pole.  No idea if I can even get a Magnum 4024 inverter, or if they are out of stock like everything else in this world.
Offline chessie4905
Re: Are the fans loud on the Magnum Energy inverters?
« Reply #1 on: August 29, 2021, 07:10:33 PM »
available on Amazon Prime (free shipping) in a couple days. you need to determine which model you need. 4024 comes in a couple configurations. Check reviews there as to noise.
also check here for price and description of accessories and options..
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.donrowe.com/Magnum-Energy-MS4024-p/ms4024.htm&ved=2ahUKEwjQsO7J1dfyAhWiMX0KHQzyCVMQFnoECB0QAQ&usg=AOvVaw0qM8Yy5G3_1BYSO5QGEcLL
Offline Dave5Cs
  • BCM Subscriber
« Reply #2 on: August 30, 2021, 04:32:52 AM »
We have a 4024 Hybrid that has load support type M.
There are some newer ones that have 6 internal spots to put in both sides of L1 and L2 now that you can run the whole electric system through the new magnums. Fans are really quite and won't bother anyone. If installed in a cool place they hardly come on. get the remote ARC50 and the battery monster and you will be good to go.
Victrons are nice too so check them out also. :^
Offline dtcerrato
« Reply #3 on: August 30, 2021, 06:59:14 AM »
Dave we have a Magnum MS2800 with the ARC50 remote. What is the battery monster!?  ???
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Offline belfert
« Reply #4 on: August 30, 2021, 07:37:01 AM »
I looked at the Sensata (Magnum) website and I am not seeing a 24 volt model that will pass through both legs of power.  They have the MSH-RV that will do that, but 12 volt only.  A 50 amp dual leg transfer switch would be a great feature to have.
« Reply #5 on: August 30, 2021, 07:59:04 AM »
I don't hear the fan on my Mangum,on the Heart it was loud,now a ? what are the ARC 50 functions I don't have that
Offline thomasinnv
  • Derrick Thomas
« Reply #6 on: August 30, 2021, 09:30:18 AM »
ARC50 = Advaned Remote Control. The RC50 and ARC50 look similar but the ARC50 has many setup features and configuration options that the RC50 does not.
1998 MCI 102-DL3
Series 60 12.7/Alison B500
« Reply #7 on: August 30, 2021, 10:05:20 AM »
I guess I don't need it all my setting are in the SliverLeaf according to the manual,I found the manual for the ARC50 in a box but no ARC50 anywhere
Offline dtcerrato
« Reply #8 on: August 30, 2021, 10:09:44 AM »
I miss spoke, I don't have the ARC50, I have the RC50. At any rate they're both remotes that literally bring the inverter and most/all it's functions & parameters to the user in a convenient place of choice. Ours is just over head in a console at the driver's seat.
Dan & Sandy
Offline hogi6123
« Reply #9 on: August 30, 2021, 10:33:22 AM »
I have a MSH4024M mounted in a bay, and an ARC50.  I'm not a "power user" but I've never noticed hearing it.  When it gets hot, some fans come on I think, but they're still pretty quiet.  Most of the time it is completely silent.
1981 MC-9
« Reply #10 on: August 30, 2021, 10:42:47 AM »
Haven't you replace the inverter before Belfert ?
Offline dtcerrato
« Reply #11 on: August 30, 2021, 10:49:50 AM »
The Magnum (now Sensata) cooling fan is a variable controlled fan and turns faster as load increases. The only way to tell how "loud" the fan is - is to put a heavy load on the inverter/charger. I say inverter/charger because one is low VDC to AC the other is AC to DC. I've heard our Magnum fan running really hard but not necessarily loud when the Charger portion of the inverter kicks in to charge a depleated battery bank. Our MS2812 Inverter/charger has a capable 125A @ 12VDC charge capacity - & when you near that kind of charge rate that fan is really singing. A Magnum tech told me that the aluminum fins on the cabinmate can get near 200F when loaded! That's another nice feature of the RC remote is that the user can dial the percentage of charge so the amp draw won't trip breakers on low amp circuits. Cliff's mention of the Silverleaf being tied into the Magnum Charger parameters is interesting. Although I shy away from that kind of computer control - ya know dinosaur...
Dan & Sandy
« Reply #12 on: August 30, 2021, 11:54:28 AM »
It has telephone plug ends just like my Traces had you just have a touch screen in 2 locations
Offline belfert
« Reply #13 on: August 30, 2021, 12:58:34 PM »
The transfer relay on my Prosine 3000 had a bunch of issues back in 2009.  A friend of mine took the relay apart and cleaned up the contacts.  The relay has been fine since then.  Scott sold me a broken Prosine 3000 really cheap.  I wanted the remote panel plus any usable parts like the transfer relay.  The relay is impossible to buy although one might be able to jerry rig a different relay.
Edit: I never really answered the question.  No, I did not replace my inverter previously.  I was probably looking for a replacement for the Prosine until my friend fixed it.
Offline belfert
« Reply #14 on: September 12, 2021, 10:29:19 AM »
Well, I managed to fix the other issue with my inverter so I didn’t order a new one.
I should have ordered a new one when I had the issue a week or two ago.  I unplugged from shore power today with no load on the inverter (breaker off in the panel).  The inverter immediately threw an error for transfer relay welded contact.  I have a parts inverter, but after opening that up I realized it is basically open heart surgery to swap the relay.
I talked with my father and some friends and decided it is time to order a new inverter.  I could spend all afternoon swapping parts and still have no working inverter.
I hate these last minute issues.
