Author Topic: Do you have a vehicle that you want to tow behind your RV?  (Read 16304 times)
  • Publisher - BCM
  • Administrator
    • BCM
« on: September 03, 2024, 11:15:08 AM »
Do you have a vehicle that you want to tow behind your RV but is not set up to be towed wheels down?  I had the same problem with my Lexus SUV.   Then I installed a Superior Driveline Driveshaft Disconnect and I have since towed it over 50,000 miles with no problem.
For more information, click on their website here.
https://superiordriveline.com/
Offline Dreadnought
  • "HMS Dreadnought"- 1964 MCI MC5
  • Live Fast, Live Well, Live Free!
    • Auto-Scape
Re: Do you have a vehicle that you want to tow behind your RV?
« Reply #1 on: September 05, 2024, 10:28:26 AM »
I wonder if these guys could adapt my jaguar x type. My ram is getting a bit much for my poor 280 bhp 8v71 to manage up mountains!
1964 MCI MC5 8v71
Offline usbusin
  • '60 PD4104-4355 (sold) and '01 Freightliner (sold)
« Reply #2 on: September 05, 2024, 10:41:01 AM »
which x? 120,140,150?
Gary D
Offline dtcerrato
« Reply #3 on: September 05, 2024, 08:19:17 PM »
You outta try a 6500lb Sierra behind an IL671 200HP 4104. We just literally love smelling the roses. Lol
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Offline lvmci
  • lvmci
« Reply #4 on: September 05, 2024, 10:17:05 PM »
I'm lucky enough to have a fiat and a jeep Comanche 4X. The fiat gets 40mpg and is an Abarth under 3000lbs. The Comanche is a true 4X for those more adventurous trips...
MCI 102C3 8V92, Allison HT740
Offline Van
« Reply #5 on: September 06, 2024, 06:42:42 AM »
If you have 4x4 with manual transfer box no need for the disconect. We tow our 1 ton 4x4 dually Sierra with the transfer box in neutral. Thanks for the help yesterday Tom  ;)
Offline Glennman
  • 1974 MCI MC-8 8V71 Turbo/2002 MCI D4500 Series 60
« Reply #6 on: September 06, 2024, 12:39:29 PM »
We just picked up a 2006 Jeep Liberty for its size and easy flat towing. The 4x4 transfer case goes in neutral and the automatic transmission in park, and away you go.
Offline Dreadnought
    • Auto-Scape
« Reply #7 on: September 09, 2024, 08:24:39 AM »
Not one of those unfortunately, although I do own a 69 XKE OTS, the x type was the cheap looking AWD jag based on the ford platform. I used it as a winter car in the Midwest, made it really dependable. Spent almost its value in parts. It’s not worth me selling now due to its very low value. It’s no bmw or mercedes but a fraction of the cost and a car I know really well. Hence I thought about adapting it. My ram 2500 cummins is outstanding but weighs over 7000 lbs!
1964 MCI MC5 8v71
Offline Iceni John
« Reply #8 on: September 09, 2024, 09:09:48 AM »
Later this month at our annual Crown bus gathering I may be looking at a VW Rabbit diesel manual pickup truck as a possible toad for my bus.   They're small and light so it could be ideal, especially as my bus has only 277 HP.   Getting well over 40 MPG is another plus point.   My car still has plenty of good life left in it, but it cannot be towed at all.
2kW of tiltable solar.
Offline plyonsMC9
  • Global Moderator
  • Big Wheels Turnin'
    • PhilLyons.com
« Reply #9 on: September 09, 2024, 11:01:32 AM »
Interesting Gary,
How long does it take to disconnect / reconnect the driveshaft?  No crawling around?
Best Regards, Phil
Offline Dreadnought
    • Auto-Scape
« Reply #10 on: September 09, 2024, 07:04:25 PM »
It’s also very easy to fix and repair. To me that’s a big one and with newer cars that’s becoming almost impossible!
1964 MCI MC5 8v71
Offline Dreadnought
    • Auto-Scape
« Reply #11 on: September 28, 2024, 03:32:58 PM »
Normally I pull a 05 cummins dodge ram 4 x 4, put the T case into neutral. No problems. Done thousands of miles with my blue ox patriot system, it’s just a lot for my poor little mc5 to pull and you can feel it struggle up hills. Hence I was thinking of adapting the jaguar x type (shitty kitty)
1964 MCI MC5 8v71
Offline Brian R.
  • 1961 MC-2 6v71, 6v92
« Reply #12 on: September 28, 2024, 09:59:20 PM »
    Let's not forget about the REMCO driveline disconnect. For 20years I towed a full sized GMC 'Jimmy' automatic (same as the Chevy Blazer), it was a diesel and a dog. The last 10 years have been towing a jeep so the unit sits in a box in storage. The REMCO worked flawlessly. It engaged and disengaged with a cable from the drivers seat. Might use it again someday,...Cheers.
  • Publisher - BCM
  • Administrator
    • BCM
« Reply #13 on: September 29, 2024, 02:41:42 AM »
Interesting Gary,
Best Regards, Phil
Phil, I put the vehicle in Neutral, grab the knob (like a choke cable) down by the console near my right leg, and pull the cable, and the driveshaft is disconnected. When I get to my destination, I reverse the procedure and re-connect the drive shaft the same way. Each procedure takes about 15 seconds...if that.
