Author Topic: Airxcel  (Read 4147 times)
Offline chessie4905
Offline David Anderson
  • just outside San Antonio TX
Re: Airxcel
« Reply #1 on: September 05, 2021, 01:03:18 PM »
Somehow, I don't think this is going to make my owning an RV and purchasing accessories a better environment for me :( :-[
David
Offline oltrunt
  • A fine BCM outting
Re: Airxcel
« Reply #2 on: September 05, 2021, 06:21:53 PM »
Accretive is good (in a slow way).  Dilutive (the antonym) is bad--right now.  I also don't think this merger will have any effect on most of us bus nuts.  Jack  ???
Offline RJ
  • VantarĂ© Conversion "Miss Vivian"
Re: Airxcel
« Reply #3 on: September 05, 2021, 10:09:50 PM »
David -
Considering Thor's QC reputation for their RVs, I certainly hope Mr Martin doesn't put pressure on Mr Rutherford to cut costs to the point that it would significantly reduce the quality of the products in the Airxcel line.
Guess we'll just have to wait and see. . .
FWIW & HTH. . . ;)
Offline richard5933
Re: Airxcel
« Reply #4 on: September 06, 2021, 03:35:36 AM »
Wonder how long it will be before another competing manufacturer sues Thor claiming they they can no longer get the components they need for their production.
Offline belfert
Re: Airxcel
« Reply #5 on: September 06, 2021, 05:13:52 AM »
I wonder if Thor will make Coleman Mach air conditioners exclusive to only Thor RVs?  My plan if one of my air conditioners were to fail is to replace with it with a Coleman Mach 8.
Re: Airxcel
« Reply #6 on: September 06, 2021, 06:26:48 AM »
I wonder if Thor will make Coleman Mach air conditioners exclusive to only Thor RVs?  My plan if one of my air conditioners were to fail is to replace with it with a Coleman Mach 8.,
Better hope your AC doesn't fail the Coleman with the heat pump are year on back order and you cannot get any friggn parts for 1 .I found 3 old stock from a dealer but he wants 1525.00 ea for the units
Offline Tedsoldbus
  • Life is not a rehearsal. Get your bus on the road.
Re: Airxcel
« Reply #7 on: September 06, 2021, 10:14:40 AM »
Might look at going "off campus". When dometic told me sucks to be you on my propane valve for my fridge, I am going to JC electric for the Amish special. Love my Dometic A/C units on the bus, but same thing. If they crap out and Dometic says "We don't make that anymore, or there is a year wait", I might try Truma. They are German engineered and recently brought to America. Sometimes you don't have to be held hostage by the monopoly. I'm looking at Truma on line. They offer a low profile Aventa model that provides 15,000 BTU of cooling. Polar Bear tested and approved....
Article about them in this months FMCA if anyone is interested.
1980 shorty (35') Prevost
6V92  HT 740
Lake Nottely Ga
Bus name "debt"
Offline dtcerrato
Re: Airxcel
« Reply #8 on: September 06, 2021, 11:04:28 AM »
We love our Dometic HE Brisk Air II. @ 13500 btu uses a measly  900W running. That's the lowest load in the industry for roof top. Two can run on a 30A circuit. A little pricey reflected by it's efficient operation.
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Re: Airxcel
« Reply #9 on: September 06, 2021, 11:50:02 AM »
I am stuck with Coleman mine are ducted no way am I tearing the ceiling out and install new air boxes for a different brand plus mine are so quite when they are blowing.1 thermostat that controls 3 units for cooling,electric heat and the Agua Hot really sucks IMO and no one seems to have a answer when the Tsat throws a code and shuts down all 3 units,when that happens I have to reboot the system again
Offline chessie4905
Re: Airxcel
« Reply #10 on: September 06, 2021, 01:18:20 PM »
too much electronics. convenient, but you get into these issues. No reason you couldn't just turn on one to three with manual switches. Anyway, never liked Dometic products clear back to 80's. I prefer Coleman and Norcold. But I guess just like tires and oil preference for some.
Offline chessie4905
Re: Airxcel
« Reply #11 on: September 06, 2021, 03:04:59 PM »
Re: Airxcel
« Reply #12 on: September 06, 2021, 03:08:57 PM »
I had good luck from the older Dometic Penguins units the newer penguins ll are pretty crappy for cooling and I too preferred Norcold over Dometic ,because Norcold was made in America
Offline dtcerrato
Re: Airxcel
« Reply #13 on: September 06, 2021, 03:10:02 PM »
I'm in no way stuck on Dometic. I'm stuck on a 13500 btu roof air that is super efficient. They exist in the mini split league but no roof air can come near a 13500 that draws 900W and easily starts on a 2500W genny or inverter. If I could find one I'd consider it. We considered mini split but have absolutely no room for it.
Dan & Sandy
Re: Airxcel
« Reply #14 on: September 06, 2021, 03:29:01 PM »
I am stuck on Coleman with 15,000 btu AC, heat pump and the condensation pump no way can I get to 7.5 amps,I am around 12 to 15 amps x 3 but that's ok if I can find out why the Tstat drops the 12v and shuts downs,mini splits are out of the question for me.so I am going to start with 3 new units and go from there
